Slow Ceiling Fan
Old 07-30-16, 07:11 PM
Received 2 Votes on 2 Posts
Slow Ceiling Fan
I have 3 ceiling fans in 3 upstairs bedrooms. Fans are same make and model. Home is approximately 60 years old.
The fan in the master bedroom suddenly decreased in speed on Hi about a month ago. I haven't changed anything on the circuit for that room.
I replaced the fan with same make and model, no change
I swapped a fan from another bedroom with the one in the master bedroom, no change.
I checked the voltage out for the fan in the master bedroom and it's 110.
I replaced the switch for the fan, no change
The only thing that looks out of whack are the wires for the fan, both white but I didn't check to see if one was just a pigtail from black.
Any suggestions much appreciated.
Old 07-30-16, 07:17 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
Nominal voltage is 120. 110 is not that low but it is suspect. You need to measure the voltage under load. Try connecting a receptacle instead of the fan plug in a lamp with an incandescent bulb and measure the voltage with the light on.
Old 07-31-16, 08:34 AM
Thanks Ray
Not sure I understand the configuration. Are you saying:
1) Turn off the fan and plug in a light on the same circuit and measure it
or
2) Disconnect the fan and wire up a socket and turn it on, measure across the socket
3) or?
There is a ceiling exhaust fan/heater and lights in the adjacent bathroom that are on that same circuit. I flipped them all on to see if there was a noticeable difference in the fan speed. There was not.
Old 07-31-16, 10:29 AM
chandler's Avatar
Received 9 Votes on 8 Posts
As long as those lights were on the same circuit, you did what Ray wanted. Is it possible the fans work off a remote control or off a dimmer switch? The physical fan must be on its highest speed for a remote control or dimmer to work properly.
Old 07-31-16, 10:32 AM
chandler, no remote, just a pull chain to change fan speed.
Old 07-31-16, 11:53 AM
ray2047's Avatar
Not sure what you mean by socket but yes, a receptacle with a light plugged in.
