Replacing [Timer] tripper did not help
Old 08-01-16, 05:35 AM
I
Post separated from http://www.doityourself.com/forum/el...-turn-off.html
I have the same problem of timer not tripping on automatically but will turn off itself. I replaced the ON tripper but it still does not work. Dial pointer will move past the ON tripper but nothing happens. Dial is snapped in. Gears are moving too. I also sprayed WD-40 behind the dial. What could be the problem?
Old 08-01-16, 08:50 AM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
Most likely is the timer is worn out. How old is it ?
Old 08-02-16, 03:08 AM
I
It's at least 9 yrs old. I figured it may be time to replace it. Thanks.
Old 08-02-16, 05:48 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
I'd replace it with a Tork timer. Intermatic timers just aren't what they used to be.
