ID this
Old 08-06-16, 03:21 PM
Doorman2722's Avatar
Received 23 Votes on 23 Posts
ID this
Does anybody know what this is? It was attached to an old mobile CB radio of my Dad's. I don't recall how it was wired to it. I'm thinking it's a filter or a 24 to 12 volt resistor? The CB may have been in a vehicle with a 24 volt system. The red and blue wire have continuity Attachment 69304
Old 08-06-16, 03:41 PM
XSleeper's Avatar
Received 792 Votes on 729 Posts
Probably a noise/static filter.
Old 08-06-16, 03:53 PM
Thanks, I believe you are right... now to figure out how to wire it up
Old 08-06-16, 04:09 PM
lawrosa's Avatar
Super Moderator
Received 63 Votes on 55 Posts
Filter........................ Red blue go in line of power cable to CB. Black is ground..
Old 08-06-16, 05:51 PM
thank you I will give it a try
Old 08-07-16, 01:12 AM
Received 1,344 Votes on 1,242 Posts
It's probably a choke/capacitor combination. Most newer vehicles don't generate the noise that was designed to filter. It may remove alternator whine if you have that problem.
I don't recall any 24v CB's. He may have had a 24v>12v convertor.
Old 08-07-16, 04:21 AM
I wired it up to my CB and it didn't make a difference I still have a whining noise through the speaker, I tried (red) wire power in (Blue) power out and then reversed them... Ran separate wire from black to ground. Maybe it is faulty? Thanks for all your help, I may order a new one
Old 08-07-16, 11:57 AM
A whining noise that changes pitch when the engine rpm changes ?
That would require a choke.
Most CB's have an ANL switch on them.... does that one and does it help ?
Old 08-08-16, 04:18 AM
Yes it changes pitch with the engine... The switch is in the ANL position, it helps a bit but still whines. I will search for a choke filter. I didn't realize there were more than one kind of filter, Thanks for your help
