Reload this Page >
Is it possible to have a circuit not attached to a breaker?
Old 08-08-16, 12:47 PM
C
Hi-
I'm replacing a light in my kitchen, and can't figure out what circuit it is on.
I turned off each breaker, one at a time, and tested the light with voltage tester - there is no light in the fixture as it is broken and won't hold a bulb- and there was no breaker that killed the power to it. I did this a second time, same result. Then as a third test I turned off the main breaker to the house. That did the trick - no power to this light fixture.
So what do I conclude w/r/t what circuit this light fixture is on?
Many thanks in advance!
Cliff
Old 08-08-16, 12:54 PM
Received 125 Upvotes on 110 Posts
If your trying to use a noncontact tester your getting a false reading.
Use a real volt Ohm meter.
Old 08-08-16, 01:04 PM
Received 3,479 Upvotes on 3,124 Posts
Welcome to the forums.
is it possible to have a circuit not attached to a breaker?
No. But it is possible thru a wiring fault to have two circuits supplying power to the same device.
After the new fixture is installed and working..... go back thru all the breakers again to find it.
Old 08-08-16, 01:50 PM
C
-I was using a non-contact tester. In fact I was checking with 2 different non-contact testers to be sure! So I will try again with a multi-tester. Thanks for the responses, will post results.
