Double Pole / Double Throw Switch Question
Old 08-24-16, 09:43 AM
Hello,
I am trying to switch between two 30AMP Outlets.
My electrician suggested:
Bryant 3025: Switches, Sensors & Chimes | Wall Switches | Bryant 3025BRN Toggle Switch, Double Pole, Double Throw, 30A, 120/277V AC, Brown | B211352 - GlobalIndustrial.com
Or Leviton: 1262 > Toggle > Switches & Motor Controls > Electrical Wiring Devices > Products from Leviton Electrical and Electronic Products
Leviton says max 24 AMPS, Bryant says 2HP. Which one is better/safer?
Also are there alternatives to these switches?
Thanks!
Old 08-24-16, 09:57 AM
Received 3,154 Likes on 2,834 Posts
For what you want to do.... you'd need to use the Bryant switch.
The other one is momentary contact..... you'd have to hold the switch either up or down.
Old 08-24-16, 10:01 AM
You mean both switches, you have to hold the switch in place?
Old 08-24-16, 10:04 AM
Sorry.... you had missed my change.
The Bryant switch stays in one of three positions.... up - center - down.
The Leviton switch stays in the center. It's spring loaded and momentary. It must be held up or down.
Old 08-24-16, 10:10 AM
Geochurchi's Avatar
The Leviton is the one you would hold in position the Bryant is the one you need ,what is your application?
Old 08-24-16, 10:11 AM
Up how much safe AMPs can the Bryant switch handle? Let's say a Whirlpool Duet Dryer...
Old 08-24-16, 10:19 AM
The rating is in the description....
