Length of wire run, panel to receptacle.
Old 08-27-16, 08:43 AM
Received 1 Upvote on 1 Post
I recently installed a new receptacle which will be the only item on a 20 amp circuit. For variety of reasons (not wanting to carve into finished walls or ceilings, or foundations), I decided to not take the shortest route from the panel to the receptacle, but are rather use cables I had put in place years ago, unused, just in case I wanted to add something to a circuit or create a new circuit.
The result is that from the panel to the receptacle, there is a run of approximately 80 feet of 12gauge wire.
Will this length of cable compromise the performance/safety of the receptacle?
The largest (and only) draw on the circuit would be a 1500 watt space heater.
Thanks in advance.
Old 08-27-16, 09:17 AM
A
Received 245 Upvotes on 225 Posts
The 80' run will not cause an issue but you might have voltage drop issues if you extend the circuit beyond the present end for additional receptacles.
Old 08-29-16, 11:42 AM
Thanks.No extension of the circuit is planned, or going to happen.
Old 08-29-16, 03:24 PM
Tolyn Ironhand's Avatar
Received 662 Upvotes on 562 Posts
I highly doubt you will have any voltage drop issues, even if you add more receptacles, or use an cord.
Old 08-31-16, 01:11 PM
Thanks for the input. The receptacle is working as expected.
