Generator wiring verification
Old 08-28-16, 01:48 PM
H
Can someone please verify that this is correct. My generator has a 30 amp outlet on it. This will plug into an inlet box (30 amp) on the side of the house. The inlet box on the side of the house has a ground two hots and nuetral... I connected the two hots to a 30amp double pole breaker in the main panel that is protected with an interlock kit. The nuetrali ran to the nuetral bar and the ground to the ground bar. I used 10/3 copper wire with ground wire. Is the 30 amp breaker and 10/3 wire good enough? It is only a 10 foot run to the main panel from the inlet.
Thanks again for everyone's help. This is my last project and done for awhile.
Old 08-28-16, 01:58 PM
Received 597 Votes on 562 Posts
If the neutral and the ground each go to their own bars..... then that sounds like a sub panel.
Your wiring sounds correct.
If your generator has a GFI breaker that trips .....
You may need to un-bond the neutral from ground inside your generator.
Old 08-28-16, 03:54 PM
P
Received 39 Votes on 33 Posts
If this is a portable generator with a bonded neutral the bonding should be removed within the generator when hooking the generator to your house wiring system.
Old 08-28-16, 06:50 PM
H
Thanks everyone... Yes i already removed the jumper wire in the generator so the neutral and ground are not connected (in the generator itself) .
In the main panel i have the nuetral to the nuetral and the ground to the ground busses. Both the ground neutral busses in the main are connected with straps and green screw to the panel (on the nuetral bar). The only reason i have the wires to separate busses is where the wire enters...it was between the two busses.
Is the 30 amp dp breaker and wire guage correct.
Old 08-28-16, 07:47 PM
Yes... the 30A wiring and breaker is correct. Technically the 30A breaker is protecting the wiring.
The breaker on the generator protects the generator.
