Intermittent buzz in circuit breaker panel
Old 08-30-16, 10:37 AM
Exclamation Intermittent buzz in circuit breaker panel
Hi,
Starting today we noticed a 5-7 second buzz that we traced back to the panel box. It happens irregularly and does not seem to coincide with the A/C cycling. To me it's a bad breaker, but I'm not sure.
Doing construction on the house, but have not touched anything electrical in over a year.
Any ideas on what this is?
If it's a bad breaker, how do I trace it down?
Is there any danger?
Thanks guys.
Old 08-30-16, 10:41 AM
Received 1,026 Votes on 952 Posts
It's usually heard on large current draw circuits.....
electric range
electric water heater
air conditioner
dehumidifier
It does not necessarily signify a defective breaker.
Most breakers are thermal/magnetic and based on the load can buzz when the load is connected.
Old 08-30-16, 11:10 AM
PJmax - thanks.
Almost nothing is running in the house, just two computers, some lights and the A/C. Nothing that you mentioned.
So where does that leave me? Sfaety?
Old 08-30-16, 11:19 AM
You could turn the main breaker off and then tighten the screws on the individual breakers.
You CANNOT tighten the screws on the main breaker.
My Square D QO panel has been buzzing for years. I can hear when the A/C starts and the pool motor.
Old 08-30-16, 12:05 PM
P
Received 93 Votes on 73 Posts
Even though PJmax did mention it directly in his first reply, the A/C has a large current draw.
Old 08-30-16, 02:03 PM
@pattenp: It doesn't correspond w/the A/C cycle.
@PJmax: meaning a potential arc on the connector screws?
Safety?
Thanks.
Old 08-30-16, 02:20 PM
R
breaker buzz
what brand is the breaker panel? does it buzz all the time? how old is the panel?
Old 08-30-16, 05:59 PM
The panel is a Crouse Hinds from the 80's.
Old 08-31-16, 04:22 PM
CasualJoe's Avatar
Received 83 Votes on 73 Posts
I am a bit familiar with those. On a Crouse-Hinds panel I found that if I turned the 30 amp breaker for the A-C on under load it would buzz. If I turned the A-C system off at the thermostat first and then turned the 30 amp breaker on, the breaker would not buzz when turning the A-C system back on at the thermostat. This was an older system with no time delay. I think it's more of a Crouse-Hinds thing than a hazard. One thing you could try once you identify which breaker is buzzing is to replace it, but Crouse-Hinds breakers are no longer manufactured. You could though use Eaton/Cutler-Hammer BR series breakers in Crouse-Hinds panels. They are listed as Bryant BR breakers on the panel label as acceptable to be used.
Old 09-01-16, 05:50 AM
Thanks CasualJoe.
I know we have some breakers that are not Crouse-Hinds but I'll have to see who made them.
Safety is the real concern. I don't want a fire. How do I determine when we've crossed the threshold into an unsafe situation?
