Gfci outlet found with no cover
Old 08-30-16, 05:46 PM
P
I just moved into my new house and i was walking outside and noticed this outlet after it rained and the kitchen outlets went out as you can see in the pictures attached its corroded and rusted
https://docs.google.com/document/d/1...?usp=drive_web
Old 08-30-16, 06:05 PM
C
Received 2 Votes on 2 Posts
Yep, time for a replacement, along with an in-use cover. You may want to consider one of these style box and in-use cover combinations:
https://www.amazon.com/Arlington-DBV...oor+outlet+box
They make a couple of different types depending on siding type.....
Old 08-30-16, 06:13 PM
Received 1,112 Votes on 1,032 Posts
Welcome to the forums.
It can be hard to see google docs.
Your receptacle is pretty well corroded. You should consider changing it for a new one and then putting an in-use cover over it.
Last edited by PJmax; 08-31-16 at 06:38 PM. Reason: added picture for the third time
Old 08-31-16, 04:05 PM
CasualJoe's Avatar
Received 86 Votes on 76 Posts
Replacement may not be so easy. It appears that the existing GFCI receptacle was installed with drywall screws. The box may have to be replaced.
Old 08-31-16, 07:03 PM
Received 77 Votes on 72 Posts
Outlet was installed without a proper siding block.
Looks like a DIY install.
Should have had a siding block like this.
http://www.lowes.com/pd/8-5-in-x--5-...Block/50394764
No clue why that price is so high, I only pay about $15.00 for the same thing.
Old 09-01-16, 11:31 AM
A
The new GFCI should be weather resistant (WR) too.
