Doorbell transformer output
Old 09-01-16, 04:03 PM
Got a ring door bell and was about to replace the current wired door bell. Measured the output voltage which read 52 volts. The ring doorbell takes max 24 volts and I read almost all doorbell is btw 8 to 24 volts. This house is like 30+ yrs old. The existing doorbell works. Is this normal? Should I get an electrician?
Old 09-01-16, 04:21 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Welcome to the forums! If you are using a digital multimeter, you could be receiving induced voltages which are inaccurate at times. Measuring with an analog meter will be more efficient. Newer doorbells are around 17 volts, so the information you have is correct.
Old 09-01-16, 04:36 PM
GregH's Avatar
Super Moderator
Received 35 Votes on 33 Posts
You are also reading open circuit voltage which could be considerably higher when no load is connected.
If your old bell works you could measure the transformer voltage and while measuring get someone to hold their finger on the doorbell.
Old 09-01-16, 06:27 PM
Received 1,036 Votes on 960 Posts
Also be sure you're on the AC volts.... not DC scale.
Old 09-01-16, 07:36 PM
Hello. Thx for the reply. I used a digital Multimeter and set the dial to 200 ACV and tested it with a household power outlet (120 v) to confirm the reading (~120v). I will definitely try holding the doorbell and measure the voltage again tomorrow when ppl are up.
Old 09-01-16, 07:40 PM
i also want to point out that i cannot find the doorbell transformer.
Old 09-01-16, 07:45 PM
It could be in the basement attached to the side of a ceiling box.
Attached to the side of the breaker panel.
Attached to some electrical box in the attic.
Someplace that no one would ever dream to look for it.
Old 09-01-16, 08:45 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Try turning off first the single pole 15a and and then 20 amp single pole breakers to find which kills the transformer. The transformer usually should be in the area of whatever else that breaker kills.
Old 09-02-16, 04:29 AM
tried holding the doorbell button while measuring the voltage. the reading drops to zero
Old 09-02-16, 04:43 AM
so i found the breaker for the doorbell, still cannot found the transformer yet. and i actually have an electric door bell (finally took the cover off). not sure if that explains why the voltage is 52 v (what the door bell need?)
Old 09-02-16, 05:11 AM
ray2047's Avatar
What else goes dead when that breaker is off? Have you removed the doorbell and looked behind it?
What do you mean? Is this really a doorbell or is it a chime? Please post a picture of your doorbell with the cover off. http://www.doityourself.com/forum/li...rt-images.html
Old 09-02-16, 05:52 AM
a few lights in laundry room and living room went dead as well.
you are right, i meant the chime.Name:  Photo Sep 02, 7 46 53 AM.jpg
here is the doorbellName:  Photo Sep 02, 9 27 46 AM.jpg
Old 09-02-16, 06:39 AM
ray2047's Avatar
It's missing the batteries.
Old 09-02-16, 07:06 AM
it is wired to a transformer. i believe only need battery if i use as wireless chime.
Old 09-02-16, 08:14 AM
ray2047's Avatar
Electronic chimes usually only use the transformer to control the chime not power it.
(An electronic chime needs DC. it's simpler/cheaper for the manufacturer to just use batteries than a DC power supply running on 17 volt AC. Second reason is they often play a longer sound such as a "rebel charge" which requires power for longer than a button push would provide. The transformer power just activates a relay to turn the chime on.)
Of course batteries may not be your only problem. The 52 volt reading makes no sense. Have you looked behind the chime for the transformer? If not I'd do a careful search of the laundry room for it checking behind ant blank cover plates and if an accessible attic over the laundry room look there. Could be on the side of an attic light or junction box perhaps buried in insulation. Of course if it works when you replace batteries you can stop looking.
Old 09-02-16, 09:52 AM
Thanks for the feedback. Due to the higher output voltage, i am considering disconnect the chime from the transformer wire (although this is probably been working for decade) and just disable for safety reason, go complete wireless. my attic has so much insulation, i doubt i will find it (already check all closet and ceiling/wall)
