Hot Outlet to Existing 3 Way
Old 09-04-16, 08:22 AM
A
Hi,
I don't believe there is anyway to do this, based on my configuration, but just wanted to verify. I have access to the hot in 3 way switch box, but not to the neutral wire. You can see it in the diagram below.
Am I right, that there is no way to do this? Or am I missing something?
Thanks,
John M.
Old 09-04-16, 09:53 AM
Received 1,027 Votes on 953 Posts
To do what..... make the light work ??
That's called a three way switch loop. Power is brought into the light and the three way switch wiring interrupts the hot wire to the light. It's a working diagram.
The new code has changed and now a neutral is required in the switch box to power electronic switches.
Old 09-04-16, 11:33 AM
A
Sorry, I see I did a terrible job in explaining what I am trying to do. Let me explain:
I have an existing 3 way switch in my basement that runs the lights. I want to add an outlet(always hot) near the one of the 3 way switches. Therefore, I thought I could power the outlet via the line that comes to the 3 way switch. I have the hot wire in the switch that I can tap off, but no neutral.
So, wanted to know what to do in this scenario? Is it even doable for me to add the outlet that runs off the load line that comes into the switch?
I understand that the code changes in 2011, but wanted to see what to do in this scenario?
Thanks,
John M.
Old 09-04-16, 12:26 PM
The confusion is caused by the wrong wording.
Your title says "Hot Outlet to ......."
You want to install a receptacle. An outlet is just a box.
No.... there is no way to install a receptacle with either three way switch based on the current wiring.
Old 09-04-16, 07:03 PM
A
Got it. Thanks for your help.
