New wiring trips breaker
Received 0 Votes
Hello everyone: I hope someone can give me an answer to this problem: I recently installed about 400 ft of UF 10/2 cable from the garage to my front gate. At the gate, I routed several runs of outlets for the lights. The problem is when I finally installed a GFCI at the beginning of the run and wired it to the existing outlet at the garage, the breaker kept tripping. Even when I removed the GFCI and just connected it to the existing outlet, the breaker still kept tripping. What did I do wrong?
You may have a ground touching an outlet terminal. Disconnect all the new outlets at end of the 10/2 and just test the 10/2 by itself. If it doesn't trip go from there connecting the outlets and testing as you go.
Received 0 Votes
Thanks. That's a good idea. Just to make sure I wired the GFCI correctly, I connected the garage outlet to the "line" side then the 10-2 to the "load" side. Did I do that correctly? The reason I asked is because before the breaker trips, I tested and verified that there was power to the line side but no power to the load side.
Just to make sure we're talking apples to apples, the breaker is the breaker in the panel tripping, not the GFCI tripping? Also I assume the existing garage outlet is not GFCI protected that you tapped off of for the new GFCI outlet. Sorry, I'm just a little confused on what's what.
