Wire AC wall wart to EL wire
Old 09-19-16, 07:30 PM
Will this AC wall wart sufficiently power this EL wire? How would I wire this safely? (more info in the image)
Old 09-19-16, 07:39 PM
Received 1,321 Votes on 1,221 Posts
Welcome to the forums.
That wall wart is 24VAC 833ma.
However we don't have any details on your Electroluminescence Wire.
I believe EL wire requires a modulated AC signal of 90-120v at very low current.
You'll probably need to buy an actual power supply designed to run it.
Old 09-20-16, 12:14 PM
Thank you PJ,
I bought an inverter that was meant for use with it, but it is very loud. I would like a solution that doesn't have a consistent loud buzz coming from it. If I did find an appropriate wall wart how would I safely wire it?
Old 09-20-16, 06:33 PM
L
Received 92 Votes on 80 Posts
The inverter/driver you purchased may be a defect or just made cheaply (maybe both?).
There shouldn't be loud buzz.
All you have to do is insulate wire connections just like you already have in the picture.
