GFCI 240v pond pump?
Old 10-06-16, 03:17 PM
7
I read on another post
http://www.doityourself.com/forum/el...uestion.html#b
that 240v motors do no require GFCI, even around water.
Is this correct?
Thanks for your assistance.
Old 10-06-16, 03:25 PM
Received 1,112 Votes on 1,032 Posts
Is your pond pump submersible or mounted away from the pond ?
That link you are quoting is not a submersible pump.
A submersible would definitely require GFI protection.
Old 10-06-16, 03:47 PM
7
It is mounted away from the lake (~10').
Seems like better safe than sorry with installing a GFCI in either situation?
Is there a reason why you wouldn't use a GFCI or why one is not required?
Thanks
Old 10-06-16, 07:05 PM
There usually isn't a reason not to use one except for the price.
I'm not sure if one is required by code if it's not submersible. Any submersed item needs to be protected.
Old 10-06-16, 07:12 PM
7
That was the only reason I could see as the standard double breaker is $8 while the GFCI double breaker is $108. But, seems like a cheap insurance policy.
Thanks for taking the time to answer my questions.
Old 10-07-16, 04:59 AM
P
Received 622 Votes on 575 Posts
I have the aeration pump on a GFCI protected circuit for my pond. Like you mentioned it's cheap insurance. Another nod to safety is that I don't pump water for a fountain. I have a rotary vane air pump that feeds bubblers. Not only is the pump well away from the water but there is also no water connecting the pump to the pond as a further nod to swimming safety.
