Reload this Page >
Wiring gauge or circuit breaker- Which defines the circuit?
Old 10-12-16, 06:25 AM
I think I know the answer, but I would like reassurance. I have a home built in 1988. The home's breaker box contains 15 and 20 amp breakers. About a 50/50 ratio. I am changing some kitchen lighting. In opening the 4" j-box I noted what I think was 12 gauge wire. When I went to the breaker box the circuit breaker was a 15 amp breaker. I thought 12 gauge was normally for 20 amp circuits. I cannot understand why an electrician would use it for a 15A circuit.
Can someone explain?
Old 10-12-16, 07:12 AM
pcboss's Avatar
Received 71 Votes on 61 Posts
The minimum gauge for a 20 amp general circuit is #12 and #14 for a 15 amp circuit. Larger csizes of wire can be instaĺled.
Perhaps there is #14 somewhere in the circuit.
Old 10-12-16, 07:13 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
It is but there is nothing wrong in using a larger size.
It is what was on the truck or some sections of the circuit has #14.
Old 10-12-16, 08:45 AM
G
Received 1 Vote on 1 Post
...or some sections of the circuit has #14.
Is that allowed by code? It seems misleading to use 12 at the panel, then switch to 14 in a junction box. If I were to make changes downstream I would base my wire & load choices by what I see in the panel.
Old 10-12-16, 09:35 AM
pcboss's Avatar
As long as the smallest conductor is protected it is allowed. It may not be best practice for the reason you stated.
Old 10-14-16, 02:05 AM
Sorry for the late reply. I got no alert that replies were made and forgot about my post.
So, I think I get it. It was OK for the electrician to use 12 ga wire on a 15A circuit. Some overkill, but OK. I find the stuff stiff and difficult to work with. I don't think I would have used it when it was not required.
More confusing yet. In a couple cases I see both 12ga and 14ga used on the same 15A circuit. Based on comments here it is still OK. Just confusing for a beginner like me.
