Subpanel Flush with Drywall and EMT exit
Old 10-12-16, 09:51 PM
U
I recently had a subpanel installed in my garage.
The panel is flush with the drywall. I'm planning on adding some circuits using EMT to the panel. What is the best way to cleanly exit the panel and the drywall?
Is there some kind of grommet that is typically used for this purpose or do I need to add a jbox where the subpanel is?
Thanks in advance for any insight into this.
Old 10-12-16, 10:43 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You could use a surface mounted 4x4 box near the top or bottom of the panel. Then just fish cable from the 4x4 box into the panel. Conduit goes into the 4x4 box.
Old 10-13-16, 09:54 AM
Z
Received 108 Votes on 100 Posts
Often the conduit simply exits the drywall and joint compound is used around the conduit to seal the hole.
Old 10-13-16, 06:01 PM
CasualJoe's Avatar
Received 85 Votes on 75 Posts
So.......this is an attached garage?
Old 10-14-16, 01:51 PM
I
Received 43 Votes on 41 Posts
You could use a stub of flex conduit from the panel to an LB fitting outside the drywall.
Old 10-14-16, 07:20 PM
U
Thanks for the replies.
To answer CasualJoe's question, the subpanel is in my unattached garage.
I think I'll probably go with some kind of surface mounted box as suggested by Ray2047. Reason being, I'm going to add a number of circuits exiting here and I think that will be the most tidy solution.
Old 10-17-16, 12:53 PM
I
In an outbuilding, this panel should have a main disconnect if you don't already have one where the feeder enters the building.
