Something weird going on inside my wall...
Old 10-13-16, 01:41 PM
V
So I'm building a home recording studio and when I plug in some of my gear and leave it on for a while I hear a banging noise inside my wall. Should I be worried about this? The first thing that came to mind was perhaps it's a live wire jumping around in there? I'm well under the circuit amp load as well...
Old 10-13-16, 03:16 PM
Received 1,042 Votes on 966 Posts
You will not hear wires banging around in the wall.
If you have hot water heat.... you may be hearing the pipe sliding on wood or possible air in the system.
Outside of that only leaves an animal in the wall.
Old 10-13-16, 03:56 PM
V
Thank you PJ. I think I figured it out. My equipment was causing vibrations after being left on for a while.
