Power outage question
Old 10-13-16, 07:06 PM
N
I have a 3000 watt generator and would love to install a manual transfer switch to my home. I simply want to power my refrigerator, one small freezer and a couple lights.
I went and bought a manual transfer switch and have not installed it yet. Upon looking at it I noticed that the plug is a 4 prong while my generator has a 3 prong female.
Considering I am not going to power many items I really wanted to be able to handle this through a switch. I am not going to power any 240 even though the generator can.
Are there adapters I can buy for the generator 3 prong female to plug my 4 prong cable for the transfer switch??
Old 10-13-16, 07:20 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
Whats the make and model of gen?
No. You probably have a 120 volt only generator. The transfer switch you have is for a 120/240 gen that will power circuits in your panel..
The only thing you can do is install dedicated generator outlets next to the outlets you want to power. When thers a power failure start the gen, plug it into the outdoor inlet , then move the plug from say the refridge to the generator powered outlet next to it..
[ATTACH=CONFIG]71881[/ATTACH]
Old 10-13-16, 07:36 PM
N
LIFAN Energy Storm 3,500-Watt 270cc Gasoline Powered Electric Start Inverter Generator with Remote-ESI3600iER - The Home Depot
This is the one I have. I wasnt planning on powering any 240 up so I was hoping there would be a switch option for when our power goes out so I could just keep the fridge cold and some lights.
Old 10-13-16, 08:07 PM
lawrosa's Avatar
Super Moderator
Are there any 240 loads in your main panel? Or are they all 120V?
Old 10-13-16, 08:11 PM
N
There are 240 loads and breakers but I didnt intend on wiring them up on the transfer station. Just a few 120v. I can certainly return this transfer station. I assume there are some 120v multi circuit solutions out there? Perhaps with the 3 prong plug options?
I am just trying to avoid wiring alternate plugs and certainly want to avoid a 2-3k generator.
Just want to keep food cold and freezer running.
I sincerely appreciate your help.
