Thermostat wiring question
Old 10-14-16, 08:19 AM
Hi,
Moving the thermostat and have to add wire. Can I use wire nuts and have the connection in-line w/o a box? Also, does running a thermostat wire along a section of A/C pose any cross-talk/interference issues for the T-stat?
Thanks.
Old 10-14-16, 10:16 AM
Received 1,019 Votes on 946 Posts
It is a gray area.
The code says splices cannot be buried. 300.15 states that splices must accessible.
However since thermostat wiring is low voltage class 2...... I don't think it falls under that restriction.
I have spliced thermostat wiring in the wall. Sometimes I solder it and use shrink tubing. Other times I've used small wire nuts. Be sure the wires are well fastened together so the splices don't get pulled apart.
Near AC wiring is ok.
Old 10-15-16, 08:00 AM
Thanks for the help Pjmax.
Old 10-18-16, 06:02 AM
P
Received 93 Votes on 73 Posts
I use wirenuts and zip tie the two ends together to prevent any pull on the wirenuts. I've never used a box.
