220 wiring question for my well
Old 10-16-16, 06:40 PM
W
my sons well is a 220 volt above ground pump, there are (in the pressure switch) 2 spots for the live wires and a ground. there is a cord mad up of regular 2 wire with a black and white (and ground) wired to a 220 volt cross slotted plug. at the receptacle the feed wire is 3 wire (red, black, white and ground) but the white wire is just capped off with a mar. Is this proper or should this be a 4 wire receptacle and the white wire carried to the pump's pressure switch and be bonded some where?
Old 10-16-16, 06:53 PM
C
Received 2 Votes on 2 Posts
No need to carry the neutral to the pump if it is 240 only. It's fine the way it is.
Old 10-16-16, 07:05 PM
W
thank you for your quick response
Old 10-17-16, 02:49 AM
chandler's Avatar
Received 5 Votes on 5 Posts
The neutral is necessary in case you decide to cover the well and need a 120 volt supply to power a heat strip or other lower voltage item. Having it capped off is fine until such use is required.
