Installing a few outlets in my garage?
Old 10-16-16, 07:38 PM
A
Hello! I've never done wiring before, but I decided to tackle adding a few outlets in my garage. I have two questions. 1. I am using metal boxes which I know need to be grounded. There is no raised area for a ground wire in this box like I've seen in other boxes. Will any of the holes do as long as I use the green wire and green screw? 2. Also, I cannot figure out how to attach this faceplate. There are 2 screws with lock nuts in the bag, but I can't figure out how to attach them to the box. Did I get the wrong faceplates? Here are two pics:
https://www.dropbox.com/s/h2lq96qcf7...62222.jpg?dl=0
https://www.dropbox.com/s/a60jj75i3p...62223.jpg?dl=0
Thanks so much!
Old 10-16-16, 08:16 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
If it is a hole tapped for 10-32 yes.
Old 10-16-16, 08:20 PM
pcboss's Avatar
Received 84 Votes on 72 Posts
There should be a tapped hole in the box for a 10-32 ground screw.
The receptacles screw to the cover plate. The cover plate screws to the box.
The garage receptacles should be gfi protected.
Old 10-17-16, 11:17 AM
A
Thanks! That helps a great deal!
