Tracing wires to junction
Old 10-31-16, 01:23 PM
I'd like to removed a bath Im remodeling from the current (haha) circuit it is on, and give it a dedicated line. I've run new lines to the bath, but now i have live wires that I don't need. Is there a way I can trace where it came from, and maybe disconnect it from it's previous junction? I hope this all makes sense.
Thanks!
Old 10-31-16, 01:56 PM
Received 1,525 Votes on 1,408 Posts
To eliminate existing wiring.... you need to determine what devices are on what circuits. You should be able to trace back thru a circuit to find a disconnect point.
If the wiring passes thru the room.... there may not be a way to eliminate it.
Old 10-31-16, 01:57 PM
I
Received 44 Votes on 42 Posts
Yes, usually you can do this by a pretty good guess. Bathrooms in older houses usually share a circuit with a kitchen, garage or basement. Are any of these on the same breaker or fuse as the bathroom?
Old 11-01-16, 08:17 AM
I mapped all the circuits shortly after we bought the house. It is the end of the line, and shares with the kitchen, living room and a bedroom. Guess I'll start with the closest and work my way out. Thanks!
Old 11-03-16, 11:55 AM
After checking almost every outlet, then switch, and even pulling down a ceiling fan, I finally found the junction it came from. Unfortunately, it's tucked away in a tiny triangle of attic above my 2nd story cape cod, and I'm just not crawling in there! It's acceptable just to leave it live, in the box, with wire nuts and tape, right?
Old 11-03-16, 12:13 PM
It's currently in a box where you've run a new circuit.... correct ?
Yes... you can wire nut it off and push it to the back of the box.
Just make sure you don't have an overcrowding problem in the box.
Old 11-03-16, 12:19 PM
Yes, I got a larger box, so it should all fit. Thanks again
