What size aluminum wire in 50A breaker
Old 11-11-16, 06:11 AM
what is the biggest size alum wire that you can fit on a standard 50 amp breaker??
Old 11-11-16, 06:29 AM
P
Received 93 Votes on 73 Posts
Usually #2, but that can vary by brand.
Old 11-11-16, 06:39 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Or you can pigtail to a smaller wire that fits.
Old 11-12-16, 09:25 AM
Geochurchi's Avatar
Received 67 Votes on 63 Posts
The breaker should list on it the min/Max size of conductor it will accept.
Old 11-14-16, 05:49 AM
have you seen guys use 2 awg alum for sub panel runs about 75 ft from a 50-60 amp breaker?
Old 11-14-16, 06:46 AM
P
Yes. I've used #2 Al SER with a 60A breaker. Also used #2 MHF 100' off 60A breakers to detached garages.
Old 11-14-16, 08:43 AM
I
Received 43 Votes on 41 Posts
Yes I've done that several times #2 al is cheaper than #6 copper.
