Blown in insulation
Old 11-14-16, 02:49 PM
Geochurchi's Avatar
Received 96 Votes on 89 Posts
Blown in insulation
Greetings, has anyone come up with a creative way to prevent blown in insulation from cascading out of a hole when cutting in ceiling boxes or recessed cans when there is no real access above.
Just curious.
Old 11-14-16, 03:15 PM
Received 108 Votes on 95 Posts
Know those plastic bases you can set a planter in so the water does run out onto the floor or deck.
Just add one to your hole saw.
What are you going to use to cut the holes?
The best way I've seen is with a ceramic grit hole saw made just the right size for the cans.
Lowe's and HD both have them in both the lighting and wiring tool area.
Better be using air tight and I/C cans.
Old 11-14-16, 04:33 PM
Geochurchi's Avatar
Just a regular hole saw,only a couple of holes.
Old 11-14-16, 08:12 PM
pcboss's Avatar
Received 114 Votes on 99 Posts
I finish the hole slowly and then try and push the insulation off to the side.
Old 11-15-16, 07:54 AM
I
Received 44 Votes on 42 Posts
Same as pcboss, just finish the cut slowly. I hold up a bucket to catch the first of it, then push the rest back. If you're careful it will mostly stay in place, but cellulose is always a dusty mess, it's just a question of how much of a mess.
Old 11-15-16, 08:11 AM
Received 1 Vote on 1 Post
No specifics "how tos" to add, but I'd strongly suggest wearing eye protection and dust mask.
