Reload this Page >
How do I convert a 3-way switch to 2-way and use the 2nd switch as a receptacle?
Old 11-23-16, 03:02 PM
Question How do I convert a 3-way switch to 2-way and use the 2nd switch as a receptacle?
I have a 3-way switch controlling a light, but I never use the second switch. However, I need a receptacle where the extra switch is located. Is there a way to connect the wires at the extra switch so that the first switch turns on the light and makes the receptacle hot at the same time?
Old 11-23-16, 03:38 PM
Geochurchi's Avatar
Received 72 Votes on 68 Posts
Hi,we need some pics of the wiring at the box you plan to install the receptacle.
Old 11-23-16, 04:01 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
(No such thing as a 2-way switch. It is just a regular switch.) Does power come in at the light or one of the switches?
Old 11-23-16, 05:39 PM
It comes in at the light.
Old 11-23-16, 11:53 PM
ray2047's Avatar
It [power] comes in at the light.
Then you probably have no neutral at either switch* so no power for a receptacle at either switch. Unless you have both a 3-conductor cable (red, black, white) and a 2-conductor cable (black, white), that's five wires plus ground at both switch boxes, easiest may be to run power from a near by receptacle.
*Assumes wired prior to 2011 code.
Old 11-24-16, 07:09 AM
I was afraid it was like this since it wasn't obvious how I could do it.
Thanks a lot. You've saved me a lot of frustration and probably a couple of shocks.
