GFCI trips when reading voltage
Old 11-26-16, 11:06 AM
Not sure what's going on, but when I check voltage in this circuit to ground reference, the gfci trips. If I check voltage to neutral reference, it does not.
Basically, why would simply trying to read voltage trip a gfci?
Old 11-26-16, 11:23 AM
Received 473 Votes on 444 Posts
Welcome to the forums.
A GFI measures the inbalance between hot and neutral. So if you test from hot to ground with a heavy enough load.... the GFI will trip due to the hot/neutral inbalance.
Old 11-27-16, 06:31 AM
Tolyn Ironhand's Avatar
Received 66 Votes on 58 Posts
GFCI's that are for protection of personnel (standard GFCIs) will trip on 4-6 milliamps. The GFCI is doing exactly what it is supposed to do.
Old 11-27-16, 01:19 PM
Received 30 Votes on 29 Posts
The act of reading a voltage draws a small amount of current.
A typical digital voltmeter draws a much smaller current than a typical analog (swinging needle) voltmeter where the latter might draw enough to trip the GFCI unit.
