Installing Honeywell RPLS740B switch
Old 12-08-16, 09:10 AM
R
I am trying to place my normal switch controlling my outdoor lights with a Honeywell RPLS740B Programmable Wall Switch. The Honeywell switch has a white, black, and blue wire on it. In the box the wire controlling the outdoor lights has a white, black, and green (ground) wire. I am not sure how to connect the Honeywell switch to these wires. If I connect the white to white and connect the blue and black wire from the Honeywell to the black wire the switch powers on but will not turn on the lights outside. Any help would be appreciated.Name:  IMG_3435.jpg
Old 12-08-16, 09:14 AM
Received 824 Votes on 774 Posts
Welcome to the forums.
If the two wires.... white and black..... from that 12-2 yellow cable go directly to the switch then you do not have a neutral connection. That timer requires a neutral.
You would need to purchase a timer that states on it "no neutral required".
Old 12-08-16, 09:56 AM
R
Thanks, that is unfortunate. Would you have a recommendation for a timer switch that would work?
Old 12-08-16, 10:59 AM
C
Received 2 Votes on 2 Posts
This one does not require a neutral, but I haven't used it so can't comment on it's performance.....
https://www.amazon.com/Intermatic-ST.../dp/B005H3AXKM
Old 12-08-16, 01:55 PM
This one will also work. Be advised that most timers that don't require a neutral require a lighting load of at least 40 watts. There is no way around that.
Programmable Timer Switch (RPLS530A) | Honeywell
Old 12-08-16, 04:47 PM
R
And I can test that with a multimeter?
Old 12-08-16, 04:53 PM
I'm sorry... test what ? .......................................
Old 12-08-16, 05:32 PM
R
You said I need a load of at least 40 watts, can I test that with a multimeter?
Old 12-08-16, 06:53 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
That means you must have at least a 40 watt incandescent light bulb. A CFL or a LED bulb won't work.
Old 04-14-17, 06:49 PM
D
Intermatic ST01 In Wall Timer no neutral and batterry
Found this through a search and adding this response in case others stumble upon the thread. Would the Intermatic ST01 with no neutral required (does require a battery) and LED compatible work?
Intermatic ST01
15 Amp Astronomic Digital In-Wall Timer - White
Controls LED and CFL lights
24-hour or 7-day digital timer with up to 20 On/Off events
Astronomic/random features, auto daylight saving time adjustment
Old 04-14-17, 07:11 PM
That timer was mentioned in post 4. Yes it will work as it uses a 3v lithium battery.
