Neutral to ground shows voltage.
Old 12-10-16, 10:11 AM
K
Exclamation Neutral to ground shows voltage.
I'm stumped on my circuit, 120v 15a. At the outlets, I'm getting an open ground reading using the three light outlet tester. Doing a voltage test at the outlets I get the following: Hot-Neutral = 124v; Hot-Ground = 47v; Neutral-Ground = 53v. I can't figure out what's going on. At the panel, everything tests out fine. Help!
Old 12-10-16, 12:09 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You need to check all the ground connections on the circuit. If you have old style BX with no bonding strip that could be a cause also.
Old 12-10-16, 01:41 PM
K
Just to clarify, this a new house with new Square D panels. I've added about 8 circuits as I'm finishing the walkout level. Everything else works fine. It's just this one circuit.
Old 12-10-16, 01:52 PM
Received 1,173 Votes on 1,088 Posts
Ok... so you more than likely have NM-b cable in place.
That means you will need to identify everything on that problem circuit and go from device to device to find the issue.
I start at the device/location closest to the panel as that's where the circuit originates from and should be ok..... and work away from that point.
