Is this the proper way to wire these circuits?
Received 0 Votes
I want to have two circuits for the lights in my pole barn. I drew this sketch to show how I plan on doing the wiring. I colored the hot wire red for clarity, but it will be black. I will be using #14 wire inside of 1/2" EMT. Is this the correct way to wire this? I hope its easy to see.Thanks. John.
I don't see a problem with the wiring. How long are the runs? You have only two lights, or will you be tapping off the two for additional? Remember you can only have a 15 amp breaker for each circuit with the 14 gauge wire, which I am assuming will be THWN/THHN...
Depending on which code cycle your location uses, you may be required to run a neutral to the switch location and cap it off. Check first.
You probably already know this, but if the picture is a junction box - you could combine the two conduits from the panel to the junction box. One 1/2" conduit can take 2 hots, 2 neutrals, and one ground.
Regardless, all grounds get connected in each box. (no desire to keep grounds separated like neutrals).
-Mike
-Mike
Maximum conduit fill for 1/2" EMT is 9 #12 conductors. You mentioned you are using #14 but I suggest you keep the maximum wire count to 9 because derating issues start if there is more then 9 wires.
