Out Side Porch Light Flickers?
Old 12-20-16, 11:59 AM
T
Received 3 Votes on 3 Posts
Hello Everyone, My front step light flickers off and On, is this a loose or broken wires inside it, can i fix it myself. How full should the bucket of water be that i will be standing in when i change it!!lol!!
Old 12-20-16, 12:44 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
First turn off the breaker and bend the tab at the bottom of the bulb socket up slightly. Turn on the breaker and test.
Old 12-20-16, 01:35 PM
T
Ok, Thanks will give it a try.
Old 12-20-16, 01:46 PM
I
Received 45 Votes on 43 Posts
Next thing to try would be to change out the switch as it is the next-likely part to go bad.
Old 12-20-16, 01:53 PM
T
I assume you mean the on and off switch, right? Thanks
Old 12-20-16, 03:52 PM
B
Received 42 Votes on 38 Posts
What kind of bulb is it and is the fixture one of the dual bright type and/or day/night?
Bud
Old 12-20-16, 04:07 PM
ray2047's Avatar
You can test if the switch is the problem also by just bypassing it. With the breaker off remove the two wires on it and connect them together. Turn the breaker back on and leve the light on long enough to see if it is still flashing.
Old 12-20-16, 04:37 PM
T
yes my friend has the same problem at his house, with both have regular 60watt bulbs in them. i will visiting him and when i get back i can try what you suggested. will let you know. Thanks Guys
