Is there code mention of outlets in closets?
Old 12-21-16, 11:28 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
I don't think I've ever seen a walk in type closet of any size with an outlet. Are they really that cheap in spec/tract houses that another $3-4 will break them? Maybe just in custom homes?
I mean, I had one at my house in VA in a small coat closet, but that's because all the pre-wiring for an alarm system terminated there. I used it to keep a dust buster charged.
Old 12-22-16, 04:35 AM
chandler's Avatar
Received 6 Votes on 6 Posts
There is not code requirement for receptacles in closets, but I agree with you that a walk in closet should have at least one for dust busters, and other periphery you want to hide from view.
Old 12-22-16, 04:41 AM
P
Received 895 Votes on 825 Posts
I put outlets in my closets when I built my house and there was no issue with code. If I recall the only electrical code issue was that the light fixtures could not be incandescent if they were within a certain distance of the walls. I think a fire prevention issue to prevent someone from piling clothes up until they touched a hot light fixture.
Old 12-22-16, 06:24 AM
pcboss's Avatar
Received 114 Votes on 99 Posts
No one is going to install another receptacle for only $3 or 4 dollars. Some also have enough trouble placing receptacles with an eye for furniture placement, let alone think about closets.
Old 12-22-16, 07:46 AM
I
Received 44 Votes on 42 Posts
They are not required by code, but not also not prohibited, so it's up to the builder / homeowner. Standard bid rate for a receptacle in new construction is about $50-60 each.
Old 12-22-16, 11:54 AM
Gunguy45's Avatar
Super Moderator
I originally just meant $3-4 for materials. I know having an outlet or switch added to existing plans can cost quite a bit, but do they really charge that much for just the basic stuff on the plan? That would mean the tiny bedroom I'm sitting in now would have cost $200-240 for just the outlets. For a job that would prob take an experienced person an hour or so.
Jeez, no wonder my VA neighbor drove new trucks every 2 years.
Old 12-22-16, 12:16 PM
Received 404 Votes on 360 Posts
I've painted 1000's of new houses over the years ranging from cheap tract homes to mansions. The only walk in closets I recall seeing receptacles in [unless wired for a specific device] is the large walk in closets that were bigger than most of the bed rms I've had over the years.
Old 12-22-16, 12:17 PM
I
Most bids are constructed to be "code minimum" (which is actually quite robust) based on the square footage of the house plus a per-unit price for additional custom lighting and receptacles beyond code. It's an estimated cost which figures in a lot of stuff. Any given receptacle is unlikely to cost $50, but when you add up all the cost associated with customizations to the plan (including additional plan review, permit and inspection fees) and divide out by number of devices, it's a decent guess.
