Main lugs on panel
Old 12-28-16, 08:15 PM
A
Main lugs on panel
Is it necessary to use noalox for a 10ga copper wire that is supplying a subpanel? If so, use it on the two hots and neutral? The lugs on the panel say al/cu, does this mean it is okay to use a copper wire or aluminum wire to the lug? Thought copper to aluminum needed a special connector? Is the lug aluminum or steel? Thanks.
Old 12-28-16, 08:32 PM
ray2047's Avatar
No it is primarily for aluminum.
Yes.
What is the minimum size wire the lug will take? Sometimes with wire as small as #10 you need to pigtail larger wire.
Old 12-28-16, 11:21 PM
A
The panel says its listed for 12 al or 14cu wire for the lug. Thanks.
Old 12-29-16, 12:18 AM
ray2047's Avatar
Good then you are good to go for 10.
Old 12-29-16, 05:51 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Where is that listing for 12al or 14cu ,on a breaker?
Old 12-29-16, 06:05 AM
A
No not the breaker rated but it is a 2 space 4 circuit small panel that is rated to accept 12al 14cu.
Old 12-29-16, 10:59 AM
Geochurchi's Avatar
If that is the case then you can't use a 10,,just curious,what is the brand and Mdl of that panel?
Geo
Old 12-29-16, 11:05 AM
ray2047's Avatar
I interpreted the answer to refer to minimum size not maximum size because I had earlier asked in post #2:
So if that is minimum size I suspect #10 is within the maximum size. Is that correct, Autostop?
Old 12-29-16, 02:26 PM
Geochurchi's Avatar
Well that's the normal marking min/max ,not the way I inturperting the information.
HNY!
Geo
Old 12-29-16, 06:41 PM
A
Size:  52.8 KBSquare D QO24L70SCP panel 2space 4 circuits 70 amps. I am misinterpreting online catalog? Thanks.
Old 12-29-16, 06:45 PM
A
ray the panel is a Square D QO24L70SCP 2space 4 circuit 70 amp panel picture from online catalog. Please advise if this accepts wire size #14-#4 cu wire. The minimum size I read is #14 cu for the main lugs and I guess for the neutral as well. I could be reading the spec incorrectly. Could you check it out please. thank you for your help.Attachment 74986 Dont know why picture came out to side. Also, I Think a qo 60 amp 2pole breaker is rated to accept #8-#2 cu wire. If the breaker does not accept the 10 gauge wire then why would the lugs?
Old 12-30-16, 05:47 AM
Geochurchi's Avatar
14 cu smallest and 4 cu largest ,just curious why you are feeding a 70 Amp panel with a #10 ?
Geo
Old 12-30-16, 08:23 AM
A
Geo,
#10 wire is already there.
Old 12-30-16, 10:47 AM
CasualJoe's Avatar
Received 179 Upvotes on 162 Posts
The lugs will be tin plated aluminum. You never want copper touching anything aluminum. The tin plating negates the copper touching aluminum. Most lugs today are all tin plated aluminum. NoAlox is for aluminum. If you want to use an antioxidant compound on a copper termination you should use Kopr-Shield.
http://www.specialized.net/Specializ...-8Oz-2265.aspx
