from Main or Sub
Old 04-24-01, 09:32 PM
Guest
Question
i'm in the process of finishing the wiring on my addition and want to run a 220v 6/3 with ground line up to the deck through the walls of the new addition for future hot tub. i installed a new 200 amp main box and from that ran a new 100 amp sub-panel. would i be better off running the new circuit off the main, which is 35 ft. further away, or from the sub-panel which is closer. thanks for any help
Old 04-24-01, 10:26 PM
Don't see any reason not to use the subpanel if it still has enough extra capacity.
