How does one show three switches on a floor plan?
I need to show a lighting diagram on a floor plan, but I'm not sure how. I want to show three switches to a light source and am not sure if they should all be designated as 4-way switches and I'm not sure how to show the arched lines between the switches and light sources. I thought 3-way and 4-way switches designated the type of switch. When there are three switches to a light source, isn't only one of the switches (the middle one) actually a 4-way switch and the other two, 3-way switches? Why would you show all three switches as 4-way? If I went to the building store to pick up switches for a three switch system, would I get three 4-way switches or two 3-way switches and one 4-way switch? Say I have a bedroom loft and on the floor plan I want to show a switch at the bottom of the stairs, one at the top of the stairs, and one at the bedside and these switches control two sconces in the loft, how would I draw that?
On a floor plan, place the three switches, connect the switches with a dashed, arched line. Make the two switches at each end S3 and the one in the middle S4. Draw a dashed, arched line from one of the S3 to the closest light and connect the lights. It's as simple as that.
Since one of the switches is on a different floor and presumably a separate drawing page, use a dashed line to a Callout describing the connection to the other floor. Do this one each floor plan.
One example similar to what Electro said.
If folks only have B/W plotters, then dashing works well too!
