Weird wiring at switch and light
Received 0 Votes
I'm trying to add a new outside light just outside my back door with using power from a current switch box and it is powered from the ceiling light currently in place. Now the weird part. It is old fiber sheathed wire that comes into the switch box. I thought the power came from the light 1st because there is only 1 set of wires that comes into the switch box and just to check i opened up the light box and only found one set of wires in there to which I assumed there would be 2 / sets (1for power in and 1 to go onto the switch). I want to put a combo switch in , 1 to run the current light and the other to run the new outside light. How do I wire this up? I know which wire is hot in the switch box but have not been able to get past that with assurance that I can wire it correctly. Is a combo switch the way to go or should I just make it 2 separate switches in a bigger box?
I have found the hot in the switch box.
Circuit
You have a switch loop. The hot you detected in the switch box is the hot leg coming from the ceiling box.
You do not have a neutral in the switch box and cannot feed power to the new light from the switch box.
can you explain how power got to the light with only 2 wires
No ground wire means you are dead in the water anyway. A circuit with no ground can't be used because code requires all new circuits must be grounded. Are there any properly grounded receptacles near where you want the porch light?
