wiring 240v receptacle
Have an existing lg30 receptacle 30 amp breaker 10gauge wire that is metal cable it is used for a table saw. The outlet is too far away from the saw. I have 4wire nm 10gauge wire that I would like to use. The existing hookup to the receptacle now is 3 wire black and red to brass terminals and there is a white wire that is hooked up to the green termina on the receptaclel. The white wire goes to the main panel neutral/ground bar. Is the mc cable supplying a ground and bond at the receptacle box as well? Withe the 4wire nm cable should the bare copper go to the green screw on the receptacle and then bond that to the outlet box? Also, red and black to breaker bare copper ground to neutral/ground bar in main panel? White wire? cutoff cap off? Thanks.![Name: IMG_0382[1].jpg
Size: 44.9 KB](https://www.doityourself.com/forum/attachments/electrical-ac-dc/75403d1483810603-wiring-240v-receptacle-img_0382-1-.jpg)
Terminology:
