Fried ground wire in screen printing flash cure dryer
Old 01-11-17, 08:06 PM
(Sorry if this thread is in the wrong sub-forum. Couldn't find exactly what I needed. Feel free to move it if required.)
I have a flash cure dryer that I use as a screen printer. (It's basically a box with heat elements in it that hovers above the shirts to dry them - like this). It was brand new and about 3 hours into using it, one of the heating elements went out. I opened it up today, pulled back the insulation, and found that the ground was fried causing the wire going to the heating element to break off. I need to replace the ground.
What could be causing this? Overload? If I replace the ground wire will it just happen again? Do you think I need to replace the whole heating element as well? I'm certainly no expert here. I just don't want this thing to become a fire hazard. I'll be happy if I can get it working again but I plan to get a better dryer and only keep this one as a back up since it's obviously not the best quality.
The plug is a 20 amp, going to a 20 amp socket, going to a 20 amp breaker. The circuit is properly grounded and good.
Thanks for any advice you can offer!!
Inside the dryer.
Close up of the bad connection.
Old 01-11-17, 08:35 PM
pcboss's Avatar
Received 40 Votes on 35 Posts
Is that the dryer or house wiring.
Normally the ground only carries currenct in the event of a fault.
Old 01-11-17, 09:18 PM
The pics are of the inside of the dryer.
Old 01-11-17, 10:01 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Do you mean the neutral wire burnt?
Old 01-11-17, 10:08 PM
Correct. It's the one that leads back to the switch on the right side in this pic-
Old 01-11-17, 10:25 PM
pcboss's Avatar
Neutrals do not get switched.
Old 01-11-17, 11:01 PM
Well whatever goes back to the switch to complete the current.
In any case I think the problem might be that whoever built this thing had a loose connection at one of the nuts. I'm gonna replace all the wires in the dryer housing with 12 gauge. I think these ones are too small.
Old 01-11-17, 11:11 PM
ray2047's Avatar
That is the hot not ground or neutral. If it is new I would return it.
Old 01-12-17, 01:16 PM
Can't return it. Flaky ebay seller! Otherwise I would.
Old 01-12-17, 01:37 PM
Received 15 Votes on 15 Posts
I'd recommend 250 deg C wire: 14awg is ok https://www.amazon.com/High-temperat.../dp/B001ALN0JG
Also, get the ceramic wire nuts.
You are wiring to 120Volts correct?
I hope that insulation is fire proof.
Old 01-12-17, 02:28 PM
Thanks for the recommendations.
It is 125V.
