Sub panel location question
Old 01-13-17, 09:37 AM
I'm finishing my basement and want to add a sub panel for all the electrical. I already have a large panel in the basement with a transfer switch for a built-in backup generator. My question is is I can place the sub panel below the transfer switch? The panel is mounted flush to the concrete wall so it will not be flush with the finished wall surface. I'm going to frame around this area and add a cover access door over the whole setup.
If I add the sub panel to the right of the main panel and below the transfer switch, it would make routing the outputs up the wall pretty long. Maybe I can immediately route the wires to the side and up through the finished wall?
Old 01-13-17, 09:53 AM
pcboss's Avatar
Received 32 Votes on 27 Posts
You can, but the neutral bars may make it more difficult .
Old 01-13-17, 10:08 AM
I'm not sure what you mean by the N bars by be more difficult. Could you explain?
Old 01-13-17, 01:24 PM
Received 42 Votes on 40 Posts
Side entry KOs on panels are right on top of the neutral bars. It can be tough to work in those panels. I'd recommend instead using a little extra wire and entering the bottom of the panel, perhaps with a chase or some conduits run down the wall.
Old 01-13-17, 01:34 PM
Got it. I understand now. Thanks for the input
Old 01-13-17, 07:32 PM
CasualJoe's Avatar
Received 26 Votes on 20 Posts
It looks to me more like a surface installation than flush.
Old 01-13-17, 07:59 PM
Haha. Yep. You are rigjt. Wrong word. I wish I could pull it off and flush mount to drywall but not worth it.
