Connecting meter base to sub panel?
Old 01-13-17, 09:18 PM
I'm wiring my own new home. Tomorrow I will run the conductors from the meter base to a sub panel. The sub panel will have a feeder that goes to my service breaker panel. My question. When I connect the (2) hot cables from the meter base to the sub panel-does it matter which pole on the sub panel I connect each hot lead to on the bus bars? Thanks for your help.
Jim in Tennessee
Old 01-13-17, 09:25 PM
Received 372 Votes on 349 Posts
When the wires leave the meter base they go to a main panel or a disconnect panel first
and then to a sub panel.
Basically there needs to be a disconnect withing 6' or so of the meter.
There will be three wires from the meter to the first panel.... 2 hots and a neutral.
The hots can go on either side.
Old 01-13-17, 09:56 PM
Thanks. I should have explained my install a bit clearer. The first panel out of my meter base does have a disconnect and actually a few positions for breakers (which I won't be using). This is the panel that my feeder to the house main breaker panel is routed. Then out of the meter base panel is another set of conductors that go to a 2nd panel. I guess this would be the official sub panel. The power from this panel will supply my HVAC, wood shop and probably hot tub. I have a 400 amp service. Thanks for helping me with the hot wire position question. I was pretty sure it did not matter which side I connected them.
Thanks
Old 01-13-17, 10:34 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
That is your main panel. The main panel is the first panel with a fuse or breaker. All other panels connected to it are subpanels.
Old 01-14-17, 05:42 AM
Thank you to everyone for your help
Old 01-14-17, 08:57 AM
ray2047's Avatar
Any more questions come on back.
Old 01-14-17, 01:10 PM
CasualJoe's Avatar
Received 26 Votes on 20 Posts
I hope the OP comes back. I was wondering if the two subpanels are each 200 amps and if they are both located at the house, I know the first one was.
