Total GFCI bathroom or not ..I need advice
Old 01-15-17, 02:49 PM
New construction: my bathroom will have 2 GFCI receptacles. It also has a vanity light, an over shower light ( not quite over the enclosure on a 10' ceiling) and a bath fan center of room. So is there a good reason to put everything in the bathroom on GFCI protection? Or not? I just want to do code or better and provide the most useful and safe electrical install. Thanks for your help.
Jim
Old 01-15-17, 02:53 PM
Oops.
I Should have mentioned in th above question that it's a 20 amp. 12 wire circuit
Old 01-15-17, 03:38 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Vanity light is best not GFCI protected so you"re not in the dark if the GFCI trips. Bath light within the footprint of the bathtub check the manufacturers instructions and local code.
Old 01-15-17, 03:57 PM
pcboss's Avatar
Received 30 Votes on 26 Posts
The NEC does not call for gfi protection for lights above a tub or shower unless the installation instructions call for it. I have never seen any that did. Exhaust fan/lights are a different story.
Old 01-15-17, 04:32 PM
Received 27 Votes on 23 Posts
Why would you use 2, GFI's in one bathroom?
One GFI would protect both outlets if wired correctly.
