200 amp meter box/ground wire
Old 01-16-17, 12:28 PM
Do I run the ground wire through conduit from meter box to ground rods?
Old 01-16-17, 02:10 PM
Received 510 Votes on 480 Posts
Welcome to the forums.
Your ground rods need to connect to the first main panel or disconnect panel.
Ground rod wiring needs to be fastened solidly but does not require conduit.
Old 01-17-17, 08:12 AM
Received 42 Votes on 40 Posts
If you do use conduit, don't use metal conduit as that opens up a can of worms you don't want to get into. I usually zip tie the grounding electrode wire to the service entrance conduit where I can or simply securely fasten it to the siding or block where there's nothing to tie it to.
Old 01-18-17, 09:32 AM
CasualJoe's Avatar
Received 43 Votes on 35 Posts
In some areas the utility requires the GEC from the ground rod/rods to be connected in the meter socket.
