New Range Hood installed, now four outlets and hood inop.
Received 0 Votes
So us noobs, took it upon ourselves to change out the hood overy our range. After installation was done, with power shut off of course, we connected the black to the house black and connected the white to the house white and connected both house grounds to the hood case. Then the moment of truth, hood didn't work and the four outlets on the circuit are inop. Also, I may have massaged the black together and got all outlets and hood operating. However, it shut off after a minute when we turned on the fan on the hood. Thinking the vibration had something to do with it, but after more fiddling, nothing is working again. Also, I accidentally touched the three white wires (two from house, one from hood) to the case of the hood and all the outlets and hood functioned. (I completed the circuit by using the case to connect to earth ground) Now I have no idea where to go from here. Thank you in advance.
Besides sounding like you have created a possibility dangerous condition by using the ground as the neutral, I think the issue is the loss of the neutral. Check all the white connections.
First off range hood by current code should not be on the receptacle circuit. It may be best to run a new circuit for the hood or go to a nearby lighting circuit.
Do you have a multimeter? (A non contact tester won't work.) Please post a picture of the wiring. http://www.doityourself.com/forum/li...rt-images.html
Did you redo each wire nut and make sure the wire was not broken inside the insulation?
Have you checked the breaker by turning it all the way off and then on?
Were the two blacks connected to each other and the two whites connected to each other when you took the old hood down?
I'm wondering if you just had a bad connection when you originally wired it. Are you using wire nuts big enough? The Pro's can probably tell by the color.
Did you pre-twist the wires (not required, but some people do it) or make sure they didn't back out when you put the nut on.
Also, is there a box in the wall? It almost looks like the cables are just coming out of a hole.
