GFCI won't reset on load
Old 01-21-17, 12:27 PM
R
Hi Guys,
Just hooked up a hot tub at our home and ran the electrical. I had the unit hooked up to a non-GFCI breaker for a while because the GFCI was on order. Just got it in, installed the breaker in the panel hooked it up to the load and now every time I turn it on it trips immediately.
Neutral wire is not touching any of the other wires and I don't believe the problem is with the hot tub panel or the disconnect outside.
Any advice on what the issue might be?
Old 01-21-17, 12:31 PM
Received 1,104 Votes on 1,024 Posts
Welcome to the forums.
I edited the title as we don't have two phase service. Homeowners have single phase service.
Did you install a two pole breaker for 240v ?
Or a single pole breaker for 120v ?
Old 01-21-17, 12:32 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
No 2-phase electric in the U.S. for 100 years. You have a 2-pole single phase breaker.
Is the white wire on the breaker connected to the neutral bar in the main panel?
Is the neutral from the hot tub connected to the neutral terminal of the breaker?
Old 01-21-17, 12:34 PM
R
Thanks guys... I meant two pole...
picture to support
Old 01-21-17, 12:37 PM
ray2047's Avatar
So you have newer type panel where the breaker clamps to the neutral bar, correct? If so the connection looks correct. Lets see a picture of the Spa panel cover removed.
Old 01-21-17, 12:58 PM
R
Here is the outside panel connected and the main panel ATTACH]76142[/ATTACH]Name:  IMG_20170121_124646.jpg
Old 01-21-17, 01:17 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
Is the neutral from the breaker connected to the neutral bar?
Old 01-21-17, 01:19 PM
R
Yea, on the right side the electrical coming in from the panel is hooked up to the top, and going out to the spa it's hooked up to the bottom
Old 01-21-17, 01:26 PM
In your spa panel..... the grounds and neutrals MUST be kept separated.
The green and the bare go into a separately installed ground bar mounted directly to the metal box.
Old 01-21-17, 01:29 PM
Tolyn Ironhand's Avatar
Received 207 Votes on 184 Posts
It appears that the grounds are connected to the neutral bus in the spa panel. They need to be separately connected to a ground bar (which you need to add) that is only attached to the steel enclosure.
(2nd time you beat me PJ. I might as well go take a nap! )
Old 01-21-17, 01:38 PM
R
Thanks for the replies!
Just did some tinkering:
Turned off the breaker to the spa, in the spa panel only connected black, red, and neutral and the breaker didn't trip. As soon as the ground was connected it did trip.
Inside the box the metal parts the white wires are connected too go underneath the plastic part that looked like it separated it before. So if i add a separate ground bar then that should fix the issue?
Old 01-21-17, 02:08 PM
pcboss's Avatar
Can you post a picture ?
Old 01-21-17, 02:36 PM
Yes.
Old 01-21-17, 06:19 PM
R
Thanks everyone for the help, that had me stumped for a while. Just finished installing the ground bus for the disconnect good times
Old 01-21-17, 06:53 PM
ray2047's Avatar
Thanks for letting us know the outcome.
Old 01-22-17, 08:10 AM
CasualJoe's Avatar
Received 86 Votes on 76 Posts
Glad you got your problem fixed. I just want to point out that you could have saved some $$ had you bought a spa panel with the 50 amp GFCI breaker factory installed.
