Washer Circuit Requirement Exceeds Breaker
Old 01-22-17, 08:22 AM
I want to buy clothes washing machine and accompanying "Pedastal Washer" which sits underneath it, both designed to wash clothes simultaneously.
Their combined "Minimum Circuit Rating" is 25 Amps, but my breaker is only 20 Amps.
QUESTION:
How much current are these machines likely to actually draw?
Top Washer:
Minimum Circuit Rating: 15 amps
Sears.com
Bottom "Pedastal" Washer:
Minimum Circuit Rating: 10 amps
https://www.kenmore.com/products/ken...e-02651992000p
Old 01-22-17, 08:30 AM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
Welcome to the forums!
Landury circuits have been 20 amps for many years and easily handles a washing machine and gas dryer. An electric dryer will require its own 30 amp 120/240 volt circuit. The laundry circuit should be able to handle two machines, but not three.
Old 01-22-17, 08:40 AM
Received 1 Vote on 1 Post
Since you are installing two washers, and their total required power exceeds a single 20 amp circuit, you will need two separate circuits; one for each. If you will also have a gas dryer it could share one of the two circuits.
You might get lucky and be able to run them for a while off a single circuit, but sooner or later they will both be pumping and spinning at the same time and pop the breaker.
Old 01-22-17, 09:35 PM
Received 16 Votes on 14 Posts
There is much confusion between minimum circuit rating and amp draw. Here minimum circuit rating is the company being lazy and not providing full information. There are very few houses in the US that have more than one 120v circuit for the laundry. If this drawer washer won't work on the same circuit as the main washer you would see it in the reviews.
Old 01-22-17, 09:47 PM
pcboss's Avatar
Received 39 Votes on 34 Posts
Are you just adding the motor loads or is there something in the instructions that state minimum size circuit of 25 amps?
Old 01-23-17, 07:38 AM
Received 42 Votes on 40 Posts
It seems like both of these units will be OK on a 20A circuit.
