Wiring a switch with receptacles between it and the light.
Received 0 Votes
A room in my home was remodeled by the previous owner a couple years ago. The power drops into the switch, down to a receptacle, across the room to another receptacle, then up to the light. 12-2 Romex was used. Currently the switch controls both the receptacles and the light. My question is, is there a way to wire this circuit so that the switch controls only the light and not the receptacles without having to run a switch leg?
You can run a switch loop from the light to the switch and change the connections at the switch.
Plan B bypass and remove the existing switch and install a wireless switch. Example: Basic Wireless Light Switch Kit - White
