Can someone help me understand my kitchen GFCI, 2 switch box wiring?
Received 0 Votes
Hi.
I've wired everything up and installed the new GFCI so there's no problems, however I'm a curious person and trying to understand electricity and circuits somewhat. I've learned a lot thanks to you guys so far!
So, as some of you may know, I've got a switchplate on the right side of my kitchen counter that has 2 switches and then a GFCI. One switch controls an overhead sink light and the other controls the garbage disposal.
There are 5 cables coming into the box. I think two are 12/2 and three are 14/2 from what I can now remember.
The POWER IN seems to go to my GFCI first on the LINE. From the GFCI the LOAD goes out to the garbage disposal switch with a white wire.
1. Is there are reason the LOAD goes out to the switch on a white wire? Should it have a tape on it?
the otherside of the garbage disposal switch has a black wire going back to the a cable and I believe the white wire from that samw cable goes to a pigtailing of all the white (neutral?) wires in the box, save for the one used for the LOAD from GFCI to disposal switch as far as I can tell.
From what I can make out I assume that the POWER for the light above the sink must come in also to this box. The light (from what I can remember) only has a 14/2 wire up at the light over the sink.
So I would assume that one of the cables coming into this box is a 14/2 and the black is going to the light switch? Then the white from that cable is ties into the NEUTRAL (white) pigtail also in this box?
I think I MAY understand it now, but I'm not sure. I'm going to try and explain what I think is happening. Maybe someone can be so kind as to verify this for me.
FIRST* I'm assuming that the NEUTRAL whites CANNOT be pigtailed together in the box if they're 12/2 and 14/2 right?
So I have three 14/2 cables and two 12/2 cables in this box. One light switch, one GFCI and one disposal switch.
1. The disposal and GFCI are on a 20 amp circuit, so that explains the two 12/2 cables in the box?
A. ONE of the 12/2 cables goes to the LINE of the GFCI
B. the LOAD goes out on a white wire to the disposal switch (which I think should be taped black).
C. The black wire from the switch goes OUT on the other 12/2 cable to the disposal unit and the white wire comes back to the neutral side of the LOAD on the GFCI from that same cable.
That takes care of the two 12/2 cables.
Now I'm a little stumped as to why there's three 14/2 cables coming into this box.
A. I assume one is a POWER IN for the light/switch circuit and one is back to the light.
B. There's another outlet behind my stove. Do you think the 3rd 14/2 must feed that one?
Received 0 Votes
The Line side is receiving the power. The load side is passing power to the next area and that item(s) will be protected by the GFCI. They will lose power if the GFCI is tripped.
I'm kinda confused by your descriptions but can tell you how my outlet for the disposal is hooked up: Black wire comes out of load gfci gold side and goes to gold screw on switch to turn disposal on/off. White line comes out silver side of gfci and is capped to white line from disposal outlet. a black line comes out of the silver screw of switch and goes to black line of disposal outlet.
Received 0 Votes
?? They are not different circuits. The pigtail merely lets me not have to stretch the white line to the outlet. Every diagram I've seen shows no neutral on the switch. The only thing different about mine, is that there are not two neutrals running to the outlet nor two hot lines. There is no room to add a dishwasher so both receptacles on the outlet go on and off with the switch.
The important thing is you realize there are two circuits in that box.
This is common in kitchens, a switch for the sink light (15A circuit) and a switch for the disposal (20A circuit).
Turn off both breakers and as boss said, keep neutrals separate.
Received 0 Votes
Thanks everyone. I haven't had time or remembered this post since I've been updating other outlets all week.
NOTE: I have NOT altered the circuit(s) in this box at all, SAVE for taking the 2 blacks going into the old outlet (one in back and one in screw) and pigtailing them. My first PIGTAIL by the way!! Am I an electrician now? LOL
So it does look to me like all the white wires in the box are PIGTAILED together, but I may have been wrong. This switch/outlet was a ROYAL PAIN to get in also since there's the fat GFCI and the 12 gauge wires to bend, etc, but I finally got it all back together and everything aligned. I kind of dread taking it all back apart, but I want to make sure I twisted the pigtail wires together correctly (I believe 95% that I did, but just want to make sure for peace of mind!). At the time I used a needle nose plier to twist the wires being ignorant to the fact that you use linesman pliers.
While I was in there I did make note of every wire and where it went, but I don't have those notes on me at this moment.
So I guess what I do know is that:
1. The POWER comes into the GFI (up until now though it was a regular outlet, since house was built in 1971) on the LINE and goes out LOAD to the DISPOSAL switch.
2. THEN it looks to me as if all the white wires in the box are PIGTAILED! YIKES I guess it's always been like this since 1971 and nothing has happened! What should I do with these wires?
3. A WHITE wire although does go from LOAD on GFI to the disposal switch. Should I change this out to a black wire? Or just mark it with some black tape?
Is there a way to find out where every one of those 5 cables coming into the box are going? I guess it would only be maybe 3 or 4 because ONE cable brings in the power to the LINE on the GFI and is a 12/2.
I'm curious though as to why the white neutrals shouldn't be PIGTAILED. Do some electricians do this?
I think a good way for me to understand what's going on in here is to make some type of diagram of the circuit(s) for myself. I could draw it out and take a picture once I get it confirmed. I'm going to have to go back in (YIKES!) and really see where all those wires go once and for all! It's more of a curiosity thing for me, but now I'm worried about all the whites being tied together!
Funny thing is everything works right .....? Hmmmm ......
The 2 blacks that you pigtailed most likely do not belong attached to the same GFCI terminal.
One should be line and the other load.
