Shimming switches and outlets
Received 0 Votes
Is it ok to shim an outlet or a switch to get it to mount straight against the wall if the outlet or switch ends up not completely perpendicular to the wall?
I did it on a couple with some left over wire insulation when I had stripped a couple wires and it seemed to work pretty good.
What I do is put it under either of the metal tabs that when the screw tightens the outlet or switch in sits against the wall that I want to bring out a little from the wall to true it to 90 degrees.
Do they sell shims for this purpose?
Here is a page of different shims found in almost ant hardware store.
https://www.lowes.com/search?searchTerm=outlet+shims
I use the GB Lego's mentioned in Don's link. However, you can't have the box sitting too far back in the wall as the gap must be closed to within 1/8". If more, then you need box extenders.
