Cooktop wiring
Old 01-29-17, 01:42 PM
A
Cooktop wiring
Can you please help. I have a new cooktop with red, black and green wires. The house supply is red, black and white wires. The old cooktop was connected red-red, black-black and the copper wire was not connected to the white wire. How would I connect the cooktop? Any help or advice will be appreciated. Thanks.
Old 01-29-17, 01:49 PM
chandler's Avatar
Received 5 Votes on 5 Posts
Welcome to the forums! If your new cooktop has no electronics on it (clock, etc.) then it is a pure 240 volt appliance and will need no neutral. There should be a grounding wire in the junction box. Do you see that? Just cap off the white wire, connect the red and black to the red and black of the stove and the ground/green to the grounding wire in the box. Let us know if you have no grounding wire.
Old 01-29-17, 01:56 PM
A
Thanks Chandler. Unfortunately there is no grounding wire in the junction box.
Old 01-29-17, 01:59 PM
pugsl's Avatar
Received 60 Votes on 56 Posts
Is your cook top a 240 volt?.................
Old 01-29-17, 02:10 PM
A
I'm not sure ... How can I tell? I think it might be.
Old 01-29-17, 02:36 PM
Handyone's Avatar
You will have to check with your local electrical/building inspector and see if they allow bonding the ground to neutral.
If bonding is not allowed, you need to install new cable with a bare ground.
The bare ground will be connected to both the metal junction box and the bare wire from the appliance whip.
Old 01-29-17, 03:02 PM
chandler's Avatar
Is the wiring for the cooktop supply in conduit? That may hold a better answer.
Old 01-29-17, 03:08 PM
E
If the "house wire" comes directly from the Main Panel, and not a sub panel, I see no problem with putting green tape on the white wire and using it as Ground.
Old 01-29-17, 03:37 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
But the NEC does. A ground in a cable must be bare or factory green.
Equipment grounding conductors can be bare, covered, or insulated. Insulated equipment grounding conductors size 6 AWG and smaller must have a continuous outer finish either green or green with one or more yellow stripes [210.5(B), 250.119].
Old 01-29-17, 04:58 PM
E
OK you got me, you are correct
