Can I use white wire for red wire pigtail?
Received 0 Votes
Have to make a pigtail to a red 14 wire, but I only have 14 white and black.
Received 0 Votes
Color code it with a colored marker or tape.
Mod Note: That is only allowed for wires that are part of a cable assembly under restricted conditions. It does not apply to wires added as pigtails unless #4 or larger.
Received 0 Votes
You can buy THHN/THWN wire (cheaply) by the foot to use for pigtails. Less confusion if you use the correct color.
So, do I just look for RED #14 NM wire or something in HD?
Red NM would actually be a type of cable sold in Canada only for 240v circuits.
Received 0 Votes
THHN/THWN is single conductor wire used in conduit. NM is cable.
Why is all the THHN wire stranded copper inside instead of solid? Just wondering.
