Bolt on Neutral lug kit question.
Old 02-05-17, 02:12 PM
N
With This type on neutral lug, does the screw that tightens the lug to the bar also tighten down the wire below it? Or, does the hole below the lug become unusable? Thanks. John.
Old 02-05-17, 02:31 PM
Received 1,104 Votes on 1,024 Posts
Reduced the size of your picture.
The screw inside the center holds the lug to the bar and there is no wire in that bus hole.
That type of lug could span 2-3 holes in the bus bar.
Old 02-05-17, 03:38 PM
N
Thank you...........................
